When I play the animation for my results of the simulation, there is a malfunction, the temperature stays the same and doesn’t change for the duration. I don’t think there is a problem with the simulation itself as sometimes I can see the final temperature, so the simulation must have worked. Is there anything I can do about this? Any help is greatly appreciated. Thanks.
Hi!
Could you please attach the project link (URL) so we can have a look? Thanks!
Thanks. From the looks of it, you probably adjusted the scale range manually to a bad range, and the results look odd.
Could you try right-clicking on the scale legend and selecting “Scale to full range”, and then playing the animation?
It should work as intended afterward.
Working now. Thanks very much.
