'rescya' simulation project by hmathias
I created a new simulation project called 'rescya':
rescya
@hmathias,
had a quick look at your model. It currently only consists of faces, there are no solids in this model. This means that the volume mesher will not be able to generate a finite element mesh from it. You can see that via the upload log after you uploaded your CAD model to SimScale (see screenshot)
Any chance you could upload a STEP model of your part? From experience this immediately solves the issue. What CAD software are you using?
David
@hmathias, STEP model looks much better! All the small fillets and especially the small angled faces at the intersections of the different fillets are still a challenge for the mesher, but it can be resolved if you make the mesh fine enough:
I used an example load case of a combined internal pressure + a force acting sideways:
Check out the full project over here:
https://www.simscale.com/projects/dheiny/rescya_1
