# Relax Factors Issue
**URL:** <https://www.simscale.com/forum/t/relax-factors-issue/87231>\
**Category:** Using SimScale\
**Created:** [December 4, 2019, 5:43pm UTC](https://www.simscale.com/forum/t/relax-factors-issue/87231 "2019-12-04T17:43:33Z")\
**Showing post:** 20
**Author:** ![dschroeder](https://www.simscale.com/forum/user_avatar/www.simscale.com/dschroeder/32/32557_2.png) [@dschroeder](https://www.simscale.com/forum/u/dschroeder)\
**Post date:** [July 2, 2020, 8:01pm UTC](https://www.simscale.com/forum/t/relax-factors-issue/87231/20 "2020-07-02T20:01:58Z")
Dale,
I have not checked the mesh quality parameters as do not have OF installed. I have never used the native OF but i am aware that it can check the mesh quality.
I can easily lower the illegal cell count by changing the max non-ortho Quality setting to 75 deg, but im still not sure if that has the desired effect.
My simulation setups and methodology is as follows:
1. I performed all my Non-ortho reduction testing on the wheels as they had a significant amount due to the geometry. This is found in my thread [here](https://www.simscale.com/forum/t/reducing-non-orthogonality-through-cad-mesh-settings-with-help-from-the-mesh-quality-feature/88804/2)
2. I used my research and new strategies to create a successful 1/2 car mesh to validate the results. This project is [here](https://www.simscale.com/workbench/?pid=2935860960297471594&mi=spec%3A866066c5-c01f-4c35-84fb-dcf834c36556%2Cservice%3ASIMULATION%2Cstrategy%3A336)
 ![image](https://www.simscale.com/forum/uploads/default/original/3X/b/2/b291eabc0264409b9bd679f59553fa70276fdbd5.jpeg)
The half car simulation was done with max non-ortho quality of 70 deg, which resluted in the following illegal cell count.
Checking faces in error :
non-orthogonality \> 70 degrees **: 2682**
faces with face pyramid volume \< 1e-13 : 15
faces with concavity \> 80 degrees : 1
faces with skewness \> 4 (internal) or 20 (boundary) : 4
faces with interpolation weights (0…1) \< 0.02 : 0
faces with volume ratio of neighbour cells \< 0.01 : 3
faces with face twist \< 0.01 : 15
faces on cells with determinant \< 0.001 : 0
This project was also the original testing ground for my radiator fan / rad fan MRF zone testing. Since this was successful, my plan was to simply make a full car sim because i naively though that this would work no problem
 ![image](https://www.simscale.com/forum/uploads/default/original/3X/7/9/792831dfa80496923cc0ae4acda9a6ef82912916.jpeg)
And the stable results with default settings for relaxation factors, with one non-ortho corrector loop
 ![image](https://www.simscale.com/forum/uploads/default/original/3X/8/6/8686fc66c266d4a42c98fe9ac634485866a646c1.png)
**Force plot**
 ![image](https://www.simscale.com/forum/uploads/default/original/3X/5/a/5a2ff92a1d4dab1c016969ca05b998bbdbf8368c.png)
**Coefficients Plot**
 ![image](https://www.simscale.com/forum/uploads/default/original/3X/6/3/636089fd042c8df7027d13f563bd999baeeb88cd.png)
These results made me think that all was well and good … NOPE.
After the first attempts at a full car simulation (with yaw, pitch, roll, and steering angle) i knew this would be a battle. I immediately had mesh failures, due to memory problems.
- I reduced the region refinement settings which fixed this
Once the mesh began to work it failed again due to the 3 adjacent faces problem.
- with support from the Simscale staff i was able to get the locations of these points on the geometry and fix it.
Then i finally get a 20 million cell mesh to work, with rotating fan assembly and all… Simulation ran out of memory.
This led me to delete the fan assembly to gain some cells back as a buffer. Since i changed this geometry, the 3 adjacent cell problem came back.
- again receive quick support from Simscale staff … geometry fixed … good mesh.
Simulate results - wildly wrong results as you saw in the links from my first post.
Now i am still confused because my half car sim with half the illegal cells ( **2682** ) worked just fine, so i dont think thats the problem … but i have no idea.
So to conclude. I have a more complicated mesh working with converged results that also has a large number of Non-ortho cells.
Dan
_[View the full topic](https://www.simscale.com/forum/t/relax-factors-issue/87231)._
