'propeller' simulation project by nfuciu
I created a new simulation project called 'propeller':
testing a propeller
NEED HELP can't get it to work
Hi @nfuciu!
Tagging our @PowerUsers_CFD here to have a look at your project.
Hi @nfuciu,
Is this supposed to be a static case meaning that your propeller isn’t supposed to be rotating? The likely reason as to why your simulation is not running is due to the outlet. You don’t want to force the air out, rather let it flow through. Try setting your outlet to pressure outlet and at zero. It should work.
