This is my first simulation here. I try to simulate a heat tranfer between a heat surce and a water cooled copper profil. The value for the heat source is 4000W. The water speed ist 0,75m/s. (400l per hour)
The temperatur diffrence between inlet and outlet is just 1 degree. Thats to low. (something around 9 degree would be right) The heat source has also a to low temperture.
I agree with you that results don’t look ok. I would expect a higher temperature drop on the fluid.
Here are some aspects that I would improve:
The copper material might have too low conductivity, please try different values for this parameter.
Finer mesh, especially to better capture gradients across the thin wall of the heat source and the fluid duct.
Allow to run for more iterations, so that residuals can get lower (2k to 3k is a good starting point). Below 1e-3 for the highest residual should be acceptable.
Try the Conjugate HT v2.0 solver.
I will tag here my colleague @RicardoParis who might be able to give deeper insides in the physics.
CHTv2 would definitely help here with convergence. On a side note: it’s very likely that the simulation results are not yet converged.
I’d highly encourage you to set result controls, especially an area average at the outlet. From the residuals alone, I cannot tell for sure if the parameters of interest are still shifting.
The result in the post process looks better. I think i need some additional iterartion to improve the result.
In the post process i want to check the surface statistic. But i can only pick the volume of the model.
I did reset the result view and reset the solution field.
