Hi jousef I was running a CHT simulation on a Airfoil tip rectangular fin but while running the simulation error notification shows up but doesn’t denote the error. Can you have a look.
https://www.simscale.com/workbench/?pid=1090981464275525243&mi=run%3A8%2Csimulation%3A4&mt=SIMULATION_RUN
And I have followed the procedures from the pdf included.
https://www.filepicker.io/api/file/aJvDk3I8RpqPgc4YUQJw
jousefm
October 27, 2018, 11:51am
Hi Tasdid,
completely overlooked your post. Let me tag @vgon_alves here and I will have a look at this as well later on.
Keeping you up-to-date! Best,
Hi everyone,
Taking a look at this one. I will write a feedback asap
Vinícius
Hi @redwanpranto15 ,
At a first improvement, try to set only one velocity direction (keep just x-direction in this case ) and please let me know if it works.
Vinícius
Hi @vgon_alves
As a uploaded a csv file for air inlet velocity the velocity was assigned to only X direction, then as you suggested I tried to remove the velocity at Y & Z direction but can’t change it
I did some modifications and, as you can see below, it is running for now. Just changing wall boundary conditions with random values. You can see that here . You can try to copy that. So let me know if any questions arise.
Vinícius
@vgon_alves
Thanks for the modifications, I just wanted to know that has the fin been kept as default no-slip wall condition?
Yes, when I do not select any conditions for the fin, SimScale automatically set the fin as a no-slip wall condition.
Vinícius
Thanks a ton man @vgon_alves you have spent a lot of your time solving my problem
No way! That is my pleasure
Vinícius
