'Presse' simulation project by Deluxee
I created a new simulation project called 'Presse':
Presse
Hi @Deluxee - any chance you can fuse the model into a single solid before uploading the CAD model, then you will not have to worry about setting up contacts. The way you have the contact setup it seems that volume2 does not have a contact associated with it?
Hey @Deluxee,
nice setup. As @AnnaFless mentioned it might make sense to fuse the model previous to simulation. I did a small setup here: https://www.simscale.com/projects/afischer/presse if you are interested.
There are several ways though. I also uploaded a partitioned model where the solid information is persisted but the interfaces are shared, that means the mesh is conform and there is no need to add contacts in that case.
Looking forward to see your setup.
Best Alex
