'polymercompression' simulation project by cyril
I created a new simulation project called 'polymercompression':
about the compression of a polymer bar
Hello @cyril!
I have received a support request from our support engineer @sjesu_rajendra. I managed to perform a quick simulation for you. Due to symmetry of the model I have just taken a small portion of the geometry i.e. of length 0.005 meters. I have done the case with and without friction. The setup you can see in this project: Polymer compression test.
The results can be seen in a small animation below:
Please note that in order to get larger model for the animation, I have used multiple times transform filter in order to transform the portions by 0.005 meters in y-direction.
I hope this helps. If you have any question/s, feel free to ask.
Ahmed
