'Plate_hole' simulation project by bloodyzohair
I created a new simulation project called 'Plate_hole':
A non linear analysis on a plate with a hole.
Hi @stadlerj ,
I wanted your inputs on the simulation.
Specifically on “Simulation 1 2 2” and its solution fields.
Thanks,
Zohair
Hi @bloodyzohair,
yes you are right! I made an error in the .csv file. For the different material model, the result field is completely different.
Thanks for the input! Gonna change it right away.
All the best from Munich
Johannes
Actually I checked my project and everything seems fine. I thought you imported the first run from my project and setup the second one accordingly.
The solution field in “Simulation 1 2 2” looks so different in comparison to my simulation because of your choice of elements. You are using a coarse mesh with linear tetrahedrons. This results in an unrealistic solution field. Try either to refine the mesh, or consider using quadratic elements.
Johannes
#5
Hi @stadlerj ,
Thanks for your insight. :slight_smile:
Yes, you are right. The solution field is unrealistic. The von Mises stress actually has a negative value, even though I have setup the simulation with your simulation as a reference except the mesh.
I will remesh the geometry and will compare the solution fields.
Zohair
#6
Hi @bloodyzohair,
the negative value is correct, since it is not the normal von Mises stress, but the signed von Mises stress. But I guess you already figured it out yourself ;)!
Johannes
