'Plastic Snap' simulation project by tnemes
I created a new simulation project called 'Plastic Snap':
Optimised Snap test
Hi @tnemes, I had a quick look at your geometry since i realized the meshing fails.
It seems that you have on a duplicate solid in your model. I think it should only consist of two parts, but it has three solids (you also see one part flickering, which indicates the duplicate):
Additionally one solid is also missing some faces:
Which software did you use to create the CAD model? Perhaps you can delete the third volume and run some healing operations to fix the missing faces issue.
Richard
