Hey
I’m trying to simulate a simple cooler for a Mosfet and have already spent 10h trying to understand what is going on and adjusting stuff. My problem is, that I always get an error if I try to create an open inner region.
Here is a picture of what the heatsink will look like in real live:
For the simulation I used a half-cut as it is symmetric and I built a box around the Heatsink with a fan-housing shaped inlet on the top and an outlet which should be similar to reality where it will open to the air.
Now the Problem is that the open inner region fails, unless I make a gap between the fan inlet on the top and the heatsink. I made the gap really small (0.01mm) but then the simulation failed, and the mesh is unnecessarily fine on this 0.01 plane. I may get the simulation working with a bigger gap, but then the air will move differently then it should. Has anyone a idea why the inner region fails with no gap in between, I mean it is still all connected. BTW I already tried redrawing it to make sure, that there are no small errors in the design, that could lead to that problem.
Thanks in advance,
Dave
