Hello, I am an f1 student trying to test the drag on my car so I can improve its aerodynamics, but the numbers don’t seem right. The test was set up as I always have done but the chart is all over the shop and doesn’t make sense.
Thank you Bill
Hi Bill, thank you for sharing!
The case here is not converged. I have a couple of suggestions:
Simulate half the model, and use the Standard mesher. You can use this tutorial as a reference.
Make sure to calculate the width of the first cell on the walls appropriately, using this guide: How to Control and Analyze Y+ in Meshing Simulation | SimScale
Toggle on the ‘Potential Flow initialization’ on the Simulation tab prior to the run.
For this type of simulation, it would be best to have at least 1000 loops performed (this is the “End time” on the simulation control panel)
