'nozzle' simulation project by sengine
I created a new simulation project called 'nozzle':
high mass-flow through nozzle
Hello all,
could someone provide some useful helps to make run this simulation? It's not clear to me what is the error. Thanks
Hi @sengine,
You can look at the public projects and see if you find a nozzle that is similar to yours. From there you can copy the project into your Dashboard or just look at it to get an idea of what the setting are in order to make the simulation run.
Let me know if you still need some help.
Hi @jousefm,
I already checked around to find a similar case. I found.
But what is particular about that is the thermophisical properties I set.
The gas is butane.
I suspect the problem is right there
