I am using SimScale for the first time. I have a solid block with holes in one face completely through the block. I uploaded this as a *.step file.
I want to set different pressures on both sides of the holes and see what air flow I get for the different hole diameters.
Unfortunately I can assign the material air only to my solid block. How can I invert that?
Do I need to build an air volume first and how to do that?
As a general rule, please always post the URL to your project alongside your issue description.
As I already had a look to your project, I will give you the answer.
What you need to do to convert your solid part into the corresponding flow region ‘negative’ is to perform a ‘flow volume extraction’ operation, as explained in the following article:
In your case, an enclosure or open inner region is what you want, depending on the needs.
