'New582017-2' simulation project by jpagan
I created a new simulation project called 'New582017-2':
The last one project from Onshape
Sam - I was able to start two simulations. The first using quick values to make sure it works and the second changing the material to steel and adding a compression pressure of about 300 MPa. It should be just above the yielding point and below the ultimate tensile strength of the steel.
I hope this helps. Let me know if you have any questions.
Jesus Pagan
@sjesu_rajendra,
this is probably addressed to you :slight_smile:
Hey, thanks Jousef (@jousefm)! I’m not sure though :confused:
@jpagan Is there anything which we can help you with?
Sam
