'Nefertiti' simulation project by jdetlefsen
I created a new simulation project called 'Nefertiti':
Nefertiti in a wind channel
Hey @jdetlefsen,
Really interesting project! I played around myself some with the mesh because I noticed that your bounding box was empty.
You want to make sure that your geometry is inside the bounding box, otherwise when you run a simulation, it will crash or not provide any results.
Your geometry is really large and it might be a good ideal to scale it down some. Also it would be better to use the SnappyHexMesh for airflow, it usually provides much better results.
I created a mesh that is okay, and might be a good start. I hope it will help some in setting up this great simulation!
https://www.simscale.com/projects/kristina/nefertiti
-Kristina :smile:
