'My Test' simulation project by japierro
I created a new simulation project called 'My Test':
This is a test
@japierro,
I quickly checked on why your meshing operation failed. The reason is that the IGES model you uploaded only contains faces, but no solids or volume information. You can see this in the upload log
The volume mesher can currently not cope with such models. I’d recommend that you upload a STEP file of the model, which generally leads to better results. Hope that helps.
David
After an export in STEP format, the meshing and simulation works straightforward, see my copied project here: https://www.simscale.com/projects/dheiny/my_test
