I’m trying to model a silicon rubber capsule containing an concentric embedded sealed cavity filled with a fluid - probably an oil or gel as yet undetermined - around a silicone rubber core. The core also has a sealed air pocket that is constrained on one side only by a very thin later of silicon rubber.
I’m trying to analyse the overall deformation and the ballooning of the thin layer when a force is applied to an area on the outside of the capsule.
I’ve created a 1/4 model in Onshape and imported that but I’m having difficulty determining how to set the material properties of the internal fluid. I’ve modelled the air-filled cavity and the external air pressure using just simple pressures at 100kPa.
Suggestions please.
Project link: https://www.simscale.com/workbench?publiclink=524cbb54-a724-4afb-aa59-8e00f219c287
