Hi! I’m currently attempting to perform modal analysis on a quadcopter for a school project. The quadcopter is symmetrical across two planes so that was the boundary condition I attempted to use. Attempting to run the simulation gives the “An Error Occurred” and a long error log in French. A link to the project is posted below. Any suggestions would be much appreciated!
FEA Squad, can you help out our user here?
Thanks!
Hi @adammet,
I think the problem may the the symmetric boundary condition you are using. While your model is symmetric modal analysis results are typically is not symmetric.
I took your model and changed the symmetry boundary condition to a fixed boundary condition and the model ran to completion. This basically gives the results for the arm, landing gear, motor combination.
Please let me know if tis helps.
Christopher
