I am trying to simulate the FSAE front wing that you find in the first worksshop of the FSAE series and I set up the mesh parameters and refinements as written in the PDF i could dowloand from the workshop session. This latter says that, due to ne fineness of the mesh it could take about 30 minutes, but in my case the mesher is running from 3 hours and it goes on.
Could somebody help me to solve this problem or to figure out why do I get it?
Thank in advance.
Hi @mbelfico,
Can we have the link of your project and document as well? so that we can compare what’s wrong.
Regards
Hi, thank you for answering.
Here it is the link : https://www.simscale.com/workbench/?pid=6780716937053308382&mi=run%3A98%2Csimulation%3A97&mt=SIMULATION_RUN
Hi again
I am sure that the mesh generation time difference is due to the numbers of computing core. Your mesh is computed using automatic number of processors setting while the one on the tutorial document was computed using other no of processors. Kindly check on the document, by the way it does not create any problem during simulation.
Hope you get the answer.
Regards
Hamza Baig
Sorry, I was sure I had chosen the 16 cose option.
Thank you
Not a problem at all:heart_eyes:
Happy to help
Stay safe stay healthy and keep SimScaling🙂
