SimScale CAE Forum
Meshing problem
hello…
i am trying to make a mesh for a cfd analysis of a pipeline in mesh log it says tessellated surface not closed
and i do not really know what does it mean?
can you help me with it please
& thanks…
Hi @TAWAKOL!
Sometimes this message can be neglected and you may proceed with the meshing process. What you can do is to share your project with us to have a closer look at it.
https://www.simscale.com/projects/TAWAKOL/alpi222/
This is the project, and the error can not be neglected.
Thanks for you attention.
Hi @TAWAKOL
There you go: https://www.simscale.com/projects/jousefm/meshing_problem/
I imported the part to Onshape and exported it as STL then simply re-uploaded to the platform, done. Let me know if there are any further questions.
Thanks a lot @jousefm , it works.
in fact i am still having another problem in boundary conditions while selecting faces,
it’s just select the whole body in stead of faces.
Hi @TAWAKOL,
If you allow me, you can create a split operation for your stl geometry to finally be able to select other faces.
1 - click on the 3 points beside the geometry’s name then choose Add geometry operation:
1
2 - Select Surface splitting (STL only)
2
3 - Put 30 degrees in the box then click Start
3
4 - You can select some faces when it finish
Please let us know if you have more questions.
Vinícius
Thanks @vgon_alves , That was very helpful :ok_hand: .
