Hello everyone, So i am trying to carry out the external aerodynamic analysis for a Airless tyre with spokes. So basically i want to carry out the simulation for two cases. One when the tyre is stationary with respect to the ground and one where the tyre is rotating. i am applying the boundary conditions as follows
Stationary Case
Inlet - Velocity Inlet - 14m/s
Outlet - Pressure Outlet - 0
Top and side walls - Slip walls
Bottom and Tyre - No slip ( Stationary)
and for rotation case
Bottom - Moving wall
Tyre - Rotating wall
But i am not getting satisfactory results for the Rotating case. However the Coeff of Drag and Coeff of Lift in the journal i am referring is 0.774 & 0.513 respectively. So after referring various literature i got to know that a mrf region should be introduced to achieve proper results for such complex geometry cases.
Iāve tried to create the mrf region and have given it a run but i am not sure whether it iss the correct approach or not, so can someone please help me out with it ?
Please be free to ask if you need any more detailss regarding the project!
Also if @1318980 or @Get_Barried can give some inputs i will be obliged
