'Mesh generation for Internal Fluid Flow' simulation project by Ali_Arafat
I created a new simulation project called 'Mesh generation for Internal Fluid Flow':
Mesh generation for internal fluid flow with Hex-Dominant parametric type.
Internal flow mesh using Hex-Dominant-Parametric mesher for a complex geometry
Quick Steps:
1- Click on geometry and click “Mesh geometry” then Choose ‘Hex-Dominant-Parametric’ and set shown parameter values.
2-Set “Explicit feature snap” to ‘true’ to capture the circular edges better.
and ‘Save’.
3-The basemeshBox coordinates are automatically generated upon save.
4-Make sure the ‘Material point’ is inside the fluid space
5- Specify necessary surface and feature refinements as shown in the project.
6- Resulting mesh:
