'MDDP Building Run 1' simulation project by hm00192
I created a new simulation project called 'MDDP Building Run 1':
MDDP wind flow project
Hi @hm00192!
Let me know if you need help with your simulation. Happy SimScaling!
Hi jousefm, can you see the simulation im trying to run? I’m trying to simulate windflow on a building, for a Masters Engineering project. Initially I was using ‘Hex-dominant automatic “wind-tunnel/external flow” (only CFD)’ for the mesh but it was giving me strange pressure results. I therefore decided to follow a method outlined by Ali Arafat, in the following project:
https://www.simscale.com/projects/Ali_Arafat/demo-vortex_shedding_around_a_building/
This creates several ‘boxes’ around the geometry and this is when my error occurs when I run the simulation. Can you help shed any light on the issue?
Many thanks,
Harry
Hi @hm00192 and sorry for the small delay.
You can also have a look at a project I did a while ago: Flow around a building
Try to follow the steps there without creating too much refinement zones - will keep an eye on your progress and help you if you need anything.
