Please can you take a look at the link and let me know what to do about the material model integration issue.
Thank you,
Raf
Thank you,
Raf
Hi Raf!
Please check this page: Error: Material Law Integration | SimScale Knowledge Base
It contains information about the source of the issue, and tips on how to resolve this. Let me know how it goes
Hi Fillia
I have already done so and I have not been able to resolve the issue.
Thank you
Raf
Hi Fillia
Please ignore my last reply to you. The load which I had tried to apply is that which would lead to element collapse. Hence the reason for not working in a static analysis. I have reduced the load to something which the structure is able to contain and the simulation is finally running.
I assume, that in order to use to see the structural collapse I would have to run the simulation under a quasi-static load. Is it possible to define a Force versus time curve or Force vs Displacement?
Kind regards,
Raf
You can get a Forces v time graph, and also a Displacement v time. By combining the data externally, you can get the forces v displacement graph as well Have a look here: How Do I Calculate Additional Results in FEA? | SimScale
Thank you Fillia.
