'Linear Static Analysis , Hanger' simulation project by delphine_genou
I created a new simulation project called 'Linear Static Analysis , Hanger':
Test the strength of an Hanger submitted to vertical loads
Hey @delphine_genou,
nice hanger. Can I help you set up your static stress analysis? Your mesh looks actually pretty fine. I guess you had some trouble with the simulation setup. Which boundary conditions did you use?
All the best
Alex
Hi
Thanks for your post. I cannot make any frequency analysis working on this part…
Is the frequency solver available?
Hi @delphine_genou, it seems that the machine just ran out of memory:
(You see the simulation run event log if you click on the specific run and scroll down in the middle panel)
Just try a larger machine by increasing the number of computing cores.
Richard
