'Leg222' simulation project by pmease
I created a new simulation project called 'Leg222':
leg sim
Hi @pmease,
I saw that this FEA simulation went smooth for you - what’s the CAD model about? Seems like you’re experienced with FEA?
When I had a look at your project, two things appeared to me: You used a 1st order mesh to run the FEA simulation. Specifically when you’re expecting bending stresses, I’d recommend using a 2nd order mesh that will give you more accurate results. You can simply choose “2nd order” during mesh generation setup:
There is a great project from @BenLewis highlighting how different mesh types impact the results of a stress analysis: https://www.simscale.com/projects/BenLewis/l_simulation_test. This image from the project shows it very nicely:
Secondly I noted that you’re using the “Static analysis” simulation type, that will only give you a limited set of boundary conditions, contact types etc.! Depending on if you need other constraints and load types to model your application more accurately, the Static Analysis - advanced simulation type will give you more control over the simulation setup.
Hope that helps and
all the best,
David
