'Konzept-3: Verbindungselement' simulation project by mfee
I created a new simulation project called 'Konzept-3: Verbindungselement':
Masterarbeit: Konzept-3 Verbindungselement
Hey @mfee!
Nice model! I had a look at your project and have some suggestions:
  1. Try to merge those solids in to one which have same material assigned to them. The more will be solids, more bonded contacts needs to be defined (which is your case are also missing). For merging the solids, you can have a look at [this] (Merging solids in Onshape and meshing) forum post. For defining bonded contacts between different solids, you can have a look at [this] (Connecting domain parts in FE analyses) forum post.
  2. You can use Static analysis - advanced which has more boundary condition options and it’s also easy to define elastoplastic material by just uploading a stress strain table. In order to perform analysis considering elastoplastic material, you can have a look at [this] (https://www.simscale.com/projects/ahmedhussain18/crane_hook_elastoplastic_analysis_1) project.
Hope this helps you performing a successful simulation. If you have any question/s, feel free to ask.Happy Simulating!
-Ahmed (@ahmedhussain18)
