'iwivos' simulation project by decwa
I created a new simulation project called 'iwivos':
iwivos is an aircraft concept
@decwa - Under mesh one you will see a node that says BaseMeshBox; it is currently set to the default values which is why only part of the mesh is generated. This bounding box needs to encompass the entire air volume around the plane.
