Is there a problem with the viewer in simscale ?
My mouse cursor will not select any faces unless it off the face . ie I have to move my mouse around away from my mesh before it highlights anything. also I usually select all the box faces and then hide selection, then select all and create a set for the model. but now when I try this it selects everything even the box that is not visible ?
It seems to be a problem with firefox. I have tried reinstalling it but I still have the same problems.
I have been using it for months with no problem so do not know whats happened there.
I have found It works fine with google chrome though so I will have to use that for now.
Update problem solved .
I have a 4k monitor so I have the text and icons set to 150 percent of size.
It was this magnification causing the problem just in the viewer. I have had to reduce the resolution and set the icon size to 100 percent and now it works fine. I do not know why I have had to do this now as it has always worked ok in the past but a least I can use it now.
thank you for reporting your issue. Your last comment is very helpful. I can reproduce the behavior that you described by changing the zoom level in the browser. Our developers will look into this.
