Project name: intercooler analysis ( conjugate heat analysis 1st simulation )
The project is about the heat transfer in intercooler.
Input parameters: inlet velocity- 28m/sec inlet temperature - 87 deg C
the ambient temperature is 30 deg C ( the solid body and fins were allotted material as aluminum with temperature as 30 deg C)
the active fluid is air
I have modeled fins in the intercooler as per design, but while meshing i face the problem of too many elements in the mesh created, due to the fins. Is there any other way where i can get the results without using the fins as such ?
Thanks!
