Ok, I am getting immensely frustrated because I am unable to troubleshoot this problem on my own through some unfortunate combination of missing knowledge, documentation, or access to generated files/data.
Here is the link to my project with a simple successful analysis: https://www.simscale.com/workbench/?pid=7823935545470138655#tab_1-0
The successful simulation is an incomrpessible, laminar steady state analysis of flow through a valve body. I utilized a hex-dominant automatic mesh, and was only successful when I calculated the mesh without grabbing the inlet and outlet faces; assigning those inlet/outlet boundary conditions of an inlet flowrate and fixed pressure and outlet flowrate respectively in the simulation designer. The simulation computed successfully and ran as expected.
The next step in better understanding both our product and this software was to run an incompressble, turbulent steady-state analysis (my plan is working gradually up through the complexity. My goal is to run a convective heat transfer turbulent, transient analysis, but I want to see all of the levels of complexity and the results from those simulations before getting to that point). Repeating this process with a handful of different meshes, a few different boundary conditions, and several attempts all fail to yield a simulation that can even be successfully calculated. I am continuously given this error: https://www.simscale.com/docs/content/support/eventLogErrors/inconsistentPatchAndPatchFieldTypesFound.html
I cannot locate, in the documentation, forums, or elsewhere, any guidance on how I can troubleshoot this problem. If I had access to the files generated at each step along the way (Actual mesh data, not just the logs generated), i’m not afraid of poring through the data to figure out which faces are being inconsistently meshed, and figuring out what I need to alter in my setup approach to prevent this problem. I have another project where I’ve tried a few other attempts to set up a turbulent problem, and I just do not understand where my mistake is. It could very well be a conceptual failing in not properly settting up boundary conditions for turbulent flow simulation (which admittedly is beyond my body of knowledge; the furthesy I understand is a graduate-level understanding of viscous laminar flow as treated in most fluids 501 classes).
Any and all help and guidance would be appreciated!!! I look forward to responses offering constructive guidance and criticism in my meshing, my simulation set-up, or somewhere else where my project is flawed (Hell I even changed my imported cad from an Inventor *.ipt file to a *.stp file which actually worked…)
Stefan
