I want to plot a graph of coefficient of pressure vs the position along the body.
Hi, @atiwary there is a result control, field calculation for pressure coefficient. As to how you could plot it might need a bit of thinking, I believe you can do more advanced plotting in offline post processing, so I’d say run the sim with the pressure coefficient field calculation then download it and open in paraview and see whats available.
If this helps and you find out how to do it, could you comment back here?
I suppose in the long run SimScale could do a result control where it reads the fields at a node… might suggest that.
Darren
