# How to improve this torque hinge simulation?
**URL:** <https://www.simscale.com/forum/t/how-to-improve-this-torque-hinge-simulation/97499>\
**Created:** [August 30, 2023, 11:33pm UTC](https://www.simscale.com/forum/t/how-to-improve-this-torque-hinge-simulation/97499 "2023-08-30T23:33:32Z")\
**Showing post:** 10
**Author:** ![tansari](https://www.simscale.com/forum/user_avatar/www.simscale.com/tansari/32/55900_2.png) [@tansari](https://www.simscale.com/forum/u/tansari)\
**Post date:** [September 12, 2023, 9:13am UTC](https://www.simscale.com/forum/t/how-to-improve-this-torque-hinge-simulation/97499/10 "2023-09-12T09:13:37Z")
After some digging, I believe your intent may have been to guide me to later use _Fictitious Clearance_ to restore the geometry dimensions after setting up the contact flush as you describe. Which would make a ton of sense, and I can see how it would help the solver.
I doesn’t help that Fictitious Clearance is [not clearly defined](https://www.simscale.com/forum/t/fictitious-clearance/6943) in the SimScale documentation – I posted a suggestion to clarify the doc. It is usually known as something like _Contact Offset_ in other software, but examples that are the first find are usually setup starting with the geometric interference like I did and let the contact solve.
I will update the geometry later and follow your steps and report on progress. I appreciate you following up on my topic @anon77415598, please be patient, I only ask these questions to understand the suggestions, and it took me a while without understanding this key point. My hope is that this topic can be useful to others as well.
_[View the full topic](https://www.simscale.com/forum/t/how-to-improve-this-torque-hinge-simulation/97499)._
