Hello, I am trying to simulate the airflow in a poultry house using simscale but I have encountered a bit of problems if you could please help me.
I am using a convective heat transfer simulation. I assigned the air material to the solid and also defined a pressure inlet and a velocity outlet boundary conditions, as well as defining heat sources in the bottom wall.
My problem is that when I try to simmulate the problem it takes too long and since I have the community plan, it stops and cancels my simmulation. I was wondering if you can tell me why it is taking so long (I have tried making the mesh less fine but it still doesn’t speed up the process. Since I am looking for temperature evolution over time, I need to simmulate for a certain time (I am trying with 1000s).
Hopefully someone can help and give me some tips.
Thank you in advance
Link to the project;
