Hi, I am simulating a NACA 0012 finite wing in incompressible external aerodynamics and measuring lift/drag coefficients and forces across angles of attack.
Here is the link to my project: https://www.simscale.com/workbench/?pid=1752549643485203317&location=simulationRun:1143d89b-a9f5-4acf-aaa1-9f433b143af4
I vary AoA by changing the inlet velocity direction in the xy plane. For an AoA α, I set:
Lift direction = (sin(α), cos(α), o); Drag direction = (cos(α), sin(α), 0)
I use V = 10m/s; Chord = 0.3m; Reference area 0.6m^2
The problem is that both my lift force and lift coefficient keep increasing across all angles. I was expecting stall to occur between 12 and 16 degrees, meaning that both lift force and lift coefficient were supposed to reach their peak and start decreasing. Instead, the rate at which they increased was decreasing, but the value kept growing even at 30 degrees. Moreover, my drag coefficient was decreasing at the start and then happened to have negative values, which contradicts my positively growing drag force value across all AoA.
I changed the orientation of the drag coefficient from (cos(α), sin(α), 0) to (-cos(α), -sin(α), 0), and of the lift coefficint from (sin(α), cos(α),0) to (-sin(α), cos(α), 0); this helped to solve the problem with negative drag coefficients. At that moment, drag was growing.
The remaining problem is that my Lift force, along with the lift coefficient, keeps increasing instead of reaching its peak and going down. I know that something in my setup is probably wrong, but I cannot determine what exactly. I would really appreciate any advice or a possible explanation for my problem.
I am simulating drag and lift to be able to check my circulation Г values with Zhukovsky’s theorem and plot a “lift produced per unit of drag” graph.
