Hello! My name is Dawson. I am new to FEA software and I am doing a research project for a class. In my project, I have a core between two plates, and I am trying to essentially “crush” the core between the plates by applying a force to the surface of one plate and leaving the other one as a fixed support in a static mechanical analysis. Unfortunately, I cannot figure out how to do this while keeping both plates rigid (i.e. just crushing the core and not deforming either plate). I have a feeling I should be using the “remote force” boundary condition, but this is failing each time, and I don’t know what point I should pick as the remote point. I would really appreciate some help with this. Thank you in advance!
Hi @dawsonsthomas!
You can simply use fixed support for one side and apply a pressure or displacement for the other side. Just in case this is relevant for you, buckling is something that is not explicitly implemented to our platform but you can use a workaround using a nonlinear analysis. Let me know if you have any further questions!
Thank you so much! I was aware that I could do these things, but my main problem is that I want the plate with the pressure to be non-deformable. Is this possible? I am trying to apply a specific pressure/force to the plate and measure its displacement.
Hi @dawsonsthomas!
What I could think of is to mesh the side you want to be undeformable very coarse and model it as rigid choosing it as a physical surface with a very high penalty coefficient. @rszoeke, would you agree to that approach or maybe any other ideas?
Hi @dawsonsthomas, @jousefm,
the penalty coefficient has no influence on the stiffness of either contact partner, so increasing that will not help in this regard. Generally there are two approaches:
- actually model the parts as “very stiff” by just using a very high Young’s Modulus for the plate
- use a remote displacement on the plate and set the behavior to “undeformable” - exactly as you did!.
If you actually are interested in the force-displacement curve (and the maximum load until it crushes), you should in general rather use a prescribed displacement instead of a force as this will be the more stable solution.
The setup of your simulation was actually correct, the only issue was that the mesh quality was too bad. You used the option “enable quadrangular surface elements” which generates in general pyramid elements and they have a bad aspect ratio on such thin walls.
I actually copied your project and added 2 simulations, one with your BC setup and prescribed force and the other with a prescribed displacement.
The main things I changed were:
- use a 2nd order mesh - for thin structures you should always use 2nd order elements to not suffer from “shear locking”
- use a nonlinear analysis - I guess you want to see the complete force-displacement curve until the panel “crushes”, so you need a nonlinear analysis that can take into account the loos of stability of the panel once it has some initial deformation and starts buckling
- to capture a full load-displacement curve and not only the last state and also since a nonlinear calculation was done, I replaced that scalar load value with a linear increasing load formula.
Some impressions on the results:
You can see the well known buckling pattern
Comparisons of the force-controlled vs. displacement-controlled simulation show the same buckling point:
Reaction force plot during runtime of the displacement controlled run. Buckling starts at step 0.5 of a total displacement of 5e-5m → Dz_crit = 0.5* 5e-5m = 2.5e-5m and Fcrit = 1312N (from plot).
Vertical displacement plot during runtime of the force controlled run. Buckling starts at step 0.525 of a total force of 2500N → Dz_crit = 2.5e-5m (from plot) and Fcrit = 0.525*2500 N = 1307N.
You can check out the project setup and the result in detail here.
Richard
Thanks for clarifying Richard - very nice explanation & documentation!
Thank you so much Richard and Jousef! I could not have asked for a more helpful explanation. SimScale is always going above and beyond, and they have provided unwavering support in my first experience with this type of software. I really appreciate this. Thank you!
