'Heatsink - with and without LED - original project of nsegers' simulation project by ahmedhussain18
I created a new simulation project called 'Heatsink - with and without LED - original project of nsegers':
This project demonstrates the steady state thermal analysis of a LED heat sink with and without LED.
Original project of @nsegers
The LED of 24 W was considered. For the first case volume heat flux on LED of 24 W/9.4 e-7 m3 ~ 25.6 e6 W/m3 was applied where 9.4 e-7 m3 is the volume of LED. The result is shown below.
Temperature contour plot with LED
For the second case, surface heat flux over the glue surface of 24 W/8.6 e-4 m2 ~ 28 e3 W/m2 was applied, where 8.6 e-4 m2 is the surface area of glue top surface on which LED is mounted. The result is shown below.
Temperature contour plot without LED
