'Heat Transfer Project' simulation project by melfaraskoury
I created a new simulation project called 'Heat Transfer Project':
Heat Analysis
Hi @melfaraskoury!
Is this a university project and did you use experimental data to validate your results?
Hi @jousefm
yes it was a university project but it was about application of linear algebra on heat transfer so i solved a certain problem in a textbook with some conditions then i have done this simulation on different shapes with the same conditions exists in my problem to show up the difference if i changed the shape
Do you want to share your results? :wink: Would be nice to see your effort!
