Hi all. For this question, we are given known temperature values at the 4 sides of a copper plate, and are tasked to find the temperature distribution within the plate.
However, when setting the boundary conditions on the 4 surfaces, I realised that there is an overlap of boundary conditions at the 4 corners of the square, causing an error of “over-constraint nodes” each time I run the simulation. I want both the upper and lower LEFT corners to follow the temperature of the left surface (75deg), and the two corners on the RIGHT to follow that of the right surface (50deg). How may I resolve this?
Here is the link to my project: SimScale
Thank you!
