'Heat transfer development between two plates' simulation project by 1318980
I created a new simulation project called 'Heat transfer development between two plates':
A project to observe heat transfer between a heated and a cooling plate and a body of water. Emphasising on observing the transition from conductive to convective dominant heat transfer and mixing.
Tags: Rayleigh-Bénard, Convection, Conduction, LES, Transient, Heat transfer, plumes, vortecies.
The development of natural convection is interesting, In this example, convection developing on two infinite plates in the X and Y-direction convecting in the Z-direction. This type of convection is commonly called Rayleigh-Bénard Convection, the lower plate is heated and the upper plate is cooled, therefore the fluid will convect in both directions.
Figure 1: Iso Surface of the developing plumes based on temperature, the top Iso Surface is clipped to allow for better viewing and the ribbons illustrate flow velocity and direction
Plume Development
Mixing
