I designed an air-guided heat dissipation structural component that needed to simulate the heat dissipation of hot air from a fan through a channel to an internal heat source. But I don't know how to set up the analysis.
Figure 4 illustrates the inlet and outlet of the internal air ducts of the entire structure. Now I want to simulate the wind hair path in the interior and the distribution of the path after blowing out, how do I set it up?Here are two inlets, do I need to create a separate outer box space as an air layer?
Thank you very much for reading and I look forward to your help!
If you wish to create a Conjugate heat transfer analysis, where the heat transfer between the solid and fluid bodies will be tested, then you can exit the CAD mode and create your simulation. If you are only interested in the flow region, delete the solid body before exiting the CAD mode (using the Delete Body feature).
This is necessary if you are creating one of the following simulations:
