'Fork Simulation' simulation project by adam_standard
I created a new simulation project called 'Fork Simulation':
Simulation on basic pallet fork
@adam_standard - I ran a quick test over here: https://www.simscale.com/projects/dheiny/fork_simulation - I’d recommend using 2nd order elements though to get more accurate results. Are you involved in fork lift design?
Yes, I am. I was simulating a fork just as an initial test case. I am having issues getting the simulated part to pull into the post-processor view however, the loading bar is just churning away after I click on the solution results and try to bring them into my window. I’m going to try and download the paraview software to see if I can do local post-processing.
@adam_standard - as the post-processor right now is still in beta, having Paraview locally is a good idea. I’ll give you access to all kinds of advanced result analysis. However the online post-processor works fine for me for your result. You only need to select the Solution fields tree item on the left, wait a few seconds, then your result field will be loaded on the right - see this (bad quality) gif animation:
Does it behave differently for you?
#5
Yes, it will not pull in the data. It is an error on our end. SSL injection, which is causing everything to slow way down.
