'Fluid flow' simulation project by amauko
I created a new simulation project called 'Fluid flow':
Fluid flow through the pipe
@@amauko - had a quick look at your setup. If you increase the value of “Write interval” to say 500 or 1000 you reduce the result data size by a factor of 10 or 20 which will make post-processing much easier. As you’re running a steady-state simulation, the intermediate timesteps are anyways only interesting for “simulation forensic”. Hope that helps.
