'Flow in pipes' simulation project by cmccreary
I created a new simulation project called 'Flow in pipes':
Test cfd with flow in pipes
@cmccreary,
are you planning on running a flow simulation through this pipe system? I had a quick glance at the model and saw that it consists out of 2 solids (see screenshot below) which might cause troubles to generate one continuous mesh. Depending on what kind of analysis you want to run, I’d suggest fusing/combining the 2 solids before uploading it.
@cmccreary - where are inlet and outlet? With that information, a simulation would be very straightforward. One could even mesh it completely automatically with the “Automatic snappyHexMesh for internal flow” mesh operation.
