'Fidget_Spinner_Flow_Analysis' simulation project by ritvizdrz
I created a new simulation project called 'Fidget_Spinner_Flow_Analysis':
Titanium fidget spinner
Nice model @ritvizdrz!
You can cut the fidget spinner in half as well as use 120° of the geometry in circumferential direction and use the cyclic boundary condition if you like. Let me know if you need any further help with it!
Thanks @jousefm
I needed help in applying the material to the model as when I am selecting the model individual faces are being selected instead of complete cad model and there are lot many faces so how do I proceed ?
Hi @ritvizdrz!
From what I can see you have just selected the faces inside the mesher which is not the material definition. I accidentally assumed that you want to perform a static analysis. In the case of a flow analysis considering a turning fidget spinner you keep the whole geometry but enclose it with a cylinder to define a MRF zone which basically means that it is not the mesh that is moving but the fluid around your component.
This project gives you an idea of what we want to achieve in the end: https://www.simscale.com/projects/gholami/propeller/
Hope that helps!
