'FEA000' simulation project by dykang
I created a new simulation project called 'FEA000':
FEA000
Hi @dykang,
You have very simple mesh friendly model. You can simplify further by removing the text “Onshape” from your model using a CAD software. I am assuming that text is not in the primary load path of your structure. Or, if you want to retain the text, you can merge the text with structure to form a single body. You can follow the following link for detailed instructions.
If you are facing any issues in the simulation or meshing, feel free to comment below.
