I tried several different meshes with this model, including standard mesh. All result with out of memory error upon running simulation. Please advise ways to potentially fix. Thanks.
A description of the project and what you are trying to achieve
Trying to simulate a fan wheel stresses up to 200 rad/sec and above.
A description of what is happening, screenshots or error logs are helpful
Screen description of error:
Creation time
Apr 29, 2023 12:59 PM
End time
Apr 29, 2023 1:10 PM
Mesh order: 2nd
Job was prepared successfully.
Number of nodes: 1,428,115
The machine ran out of memory. Please choose a larger machine by increasing the number of computing cores or reduce the domain size and/or the fineness of your mesh.
[Important] Always provide a link to your project so that it is easy to find.
Hello @melizabeth , thanks for using the SimScale Forum!
The first thing I noticed is that all faces have been assigned a remote displacement boundary condition, and all displacements (translation, rotation in all axes) are constrained to zero. I suggest only applying this boundary condition where the part is actually supported, and using a Fixed Support boundary condition may be another alternative.
To optimize computational resources and time, I recommend using the Cyclic Symmetry boundary condition for this application.
