I am trying to run a cfd simulation of an open wheel racecar with an undertray/diffuser. I have done a number of successful simulations already but for the simulation: “ut7”, I am getting an error (Fatal I/O error) shortly after I run the simulation. Could someone give me some advice on how to fix this?
Project link: Https://www.simscale.com/workbench/?pid=928092988515042305#tab_0-0
Thanks in advance.
Hi @msimnado,
This is very strange indeed, I do not see any glaring issues with the simulation. Have you tried to start the simulation more than once? Sometimes I encounter this issue with no obvious issues but a simple re-run with nothing changed works.
Do let me know.
I tried re-running the simulation and also starting from scratch with the geometry, got the exact same error.
Hi @msimnado,
I saw you got the simulation running well for “ut8”! Did you solve the issue already?
i think so, i just refined the outer region mesh slightly for that simulation, hopefully i don’t run into any other problems.
Ah. Interesting fix. Hopefully it goes well!
