'extraclick' simulation project by colincorey1
I created a new simulation project called 'extraclick':
ratchet device
@colincorey1,
I just had a quick look at why your meshing failed. The reason is that the IGES model you uploaded only contains faces, but no solids or volume information. You can see this in the upload log
The volume mesher can currently not cope with such models. I’d recommend that you upload a STEP file of the model, which generally leads to better results. Does your CAD system support a STEP export?
David
